sikeston34m
sikeston34m's Avatar
09.20.2009, 07:00 AM
Originally Posted by aqwut View Post
25K is not the limit, I have ran the 1700KV motor on 8S, and it was insanely fast... I recommend somewhere around the 25K mark.
Example, 1200 KV and 2000 KV motors of the same size.. Powering a Monster Truck...
They both have the same power output.. with the lower KV you have to gear higher and use more voltage, and with the higher KV you'd have to gear lower and use less voltage.
I prefer to use lower KV and higher voltage & less RPMS.. but there is a limit..
Lower KV motors can't take as much amps as the higher KV.. the Lower KV relies more on Voltage.. whereas the Higher KV motors relies on Current. know what I mean?
Hi Aqwut,
How about a KB45 10xl in an E Revo?
Let's gear it 20/40 using mod 1 gears, then put in on 6S with a MMM ESC.
How do you think this setup will do, according to your experience with the KB45?
Geared for 44mph according to BG's speed calculator, and spins up to 26,640 rpms.
Also, Where can I find a heatsink/fan for this beast of a motor?
aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.20.2009, 08:25 AM
Hi Aqwut,
I think you have a solid (cheap $) setup there man... that should do you really good..... I use a 40mm x 20mm fan, and just zip tie it around the motor... 20/40 gearing comes up to only 36MPH.. for my revo 3.3.. Wouldn't you need 22/36 for 45MPH..?
and that motor is plenty powerful for that revo.. Awesome!
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
sikeston34m
09.20.2009, 05:23 PM
Thank you for your reply.
Here are the values that the speed calculator gave me. It LOOKS correct.........hmmmmm..........
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.8333333333333332
Other Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 20
Total Voltage: 22.2
Motor KV: 1200
Tire Diameter (inches): 5.75
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2 : 1
Total Ratio: 10.4359 : 1
Tire Circumference (inches): 18.06 inches (458.83 mm)
Rollout: 1.73:1
Total Motor Speed: 26640 RPM
Vehicle Speed: 43.67 mph (70.15 km/h)
Effective KV Value: 1200
KT constant: 1.13 oz-in/A
The difference is probably in the transmission gear ratio.
aqwut
aqwut's Avatar
09.20.2009, 07:19 PM
Other Ratio: 1
Total Voltage: 22.2
Motor KV: 1200
Rollout: 1.73:1
Oh you're right.. I misread, I just assumed that E-Revo means a converted Nitro to Brushless..
sikeston34m
09.20.2009, 11:35 PM
Here's an interesting tidbit of information:
http://www.castlecreations.com/products/cc_blower.html
"A must have for any hardcore basher or temperature freak. Includes, fan, shroud, and two (2) black zip ties. Fits on motors with outside diameters between 1 1/2" and 1 7/8"."
1 7/8" = 47.625mm
The KB45 motors are 45mm in diameter!
This could be a GREAT solution to keeping temps in hand.
sikeston34m
09.21.2009, 12:30 AM
Would the KB45 10XL work on 4S geared for 40mph?
This would mean the setup would look like this:
Other Ratio: 1
Spur Tooth Count: 36
Pinion Tooth Count: 25
Total Voltage: 14.8
Motor KV: 1200
Spur/Pinion Ratio: 1.44 : 1
Total Ratio: 7.51385 : 1
Rollout: 2.40:1
Total Motor Speed: 17760 RPM
Vehicle Speed: 40.43 mph (64.95 km/h)
I wonder what kinda Amp spikes we would be look at?
That's some pretty tall gearing.
aqwut
aqwut's Avatar
09.21.2009, 06:34 AM
Sure it would...! ... if it's cogging at the start, then it's geared too high..
I would do a little bit higher RPMs though.. that's a tad bit low..
if running wanting to use 4S, I would do the 1700KV...
My opinion, Gear it high with the 1000KV KB-45XL...
Nixpus
09.25.2009, 07:58 AM
Had time to play a bit with my 08XL yesterday.
Drive shaft is 4.99mm now.
Front and end bell is modified with four 9mm air vent holes.
After assembling the motor again I was thinking about attaching a 40mm pc fan to the end. This would allow me to force air through the motor... internal cooling FTW
One of my colleagues came up with another idea. Attach some wings on one end of the magnet in order to create turbulence... this would then hopefully force air through the motor (or maybe it will just sound like a siren )
If I can force the rotor itself to act as a fan thats a winner... just have to figure out how to attach a dust filter to the "air intake end".
Hmm... I need to make some tests and see what gives the best results.
Any bright ideas or additions?
kb45 L and xl
ghostriderlund
speedfreak.dk
kb45 L and xl - 09.25.2009, 01:01 PM
Hello. i have been running those babyes for 4 years now.
i always pick the top kv rated ones so i play with kb45 2300kv l can. and the bigger one kb45 1700kv xl. i bought them way back before they changed the kv to 1600kv for the xl version.
and the biggest problem people do is that they gear them to low and the will overheat because they have nothing to do.. you all know that running a brushless motor unloaded is a no go right ?
i run 10cells lipo in series trough 2300kv kb l version for speedruns and 5-6cells lipo for offroad and bashing. never has any problems.
i run twinforce and rustler and 1:8 buggy and truggy and revo and cen gst with those motors..
the big hw heatsink cooler for the 2000kv motor is great and the holes in the front and back is also good.
No offense but i think you guys in here run weak setups . but its the place with the most info in one place. i run up to 9cells lipo in series in the neu mamba 2200kv motor. stil dont think it is as sharp as the kb 2300kv L
the bigger 1700kv xl is easyer to handle because of lower rpm and it really does a nice job in rustler as a speedrunner.
i prefer hobbywing plane esc and i dont run the pistix as it gets to sick. i use rubber band and gets a full travel on the remote and then its easyer to handle.
the 40k rpm limit is for the nitro guys.. we run eletric and the fun starts at 70.000k rpm
so please put some more lipos in your rc cars :)
best regards from denmark
sikeston34m
01.29.2010, 12:41 PM
I just acquired a couple of 25 tooth Mod 1 gears with the 6mm ID.
This NEW KB45 10 XL had just been sitting around waiting for some action.
Here is my proposed setup now:
E Revo
MMM
Apogee Limn 3800mah 6S or 6S Turnigy 5000mah
KB45 10XL geared 25/40 using Mod 1 gears
Now the only thing I'm missing is those m4 screws to mount the motor with.
Where can I find those pesky things?
How well will this setup work?
