DonovanP
09.22.2009, 01:35 PM
Haha only you replying to my threads..lol Thanks!
Mm I would buy one if they had stock.And they can't tell me when that will be.So need to make one till the stock comes in.Or import a few..
I will see what I can do tomorrow.Have a few clutch bells here I can butcher..lol
rchippie
rchippie's Avatar
09.22.2009, 01:39 PM
Mike has them in stock i belive, or you can Try seeing if one of our europen members has one they can send you . If your going to use a CB. Make sure you use a hardenend one or your just wasting your time . Ther way ben is describing is the way they were made . But griffin used STAINLESS stell instead of aluminum . Just make the hub bug enough so you get good bite from the set screw .
REAL MEN RUN BRUSHLESS
DonovanP
09.22.2009, 01:47 PM
I might end up buy from here if the local shops take to long to get stock..
But will see what I can do just to get up and running.I have hardened 14t bell I can cut..Will get on the lathe tomorrow and see what I can cook up!
rchippie
rchippie's Avatar
09.22.2009, 01:54 PM
I remember griffin telling me he had to use a big press to get the SS insert into the CB gear .
DonovanP
09.22.2009, 02:03 PM
Okay so its a tight fit..lol..Will make a plan.Have access to a press.Thanks for the info!
