Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
09.24.2009, 01:15 AM
I think the Spektrum Rxs can handle up to 9V
Now that you mention.. yeah I think it was 9.6 even, but what about the Futaba owner who tries to use one of the JR servos at 8.4.......
so i went and picked up the castle bec pro good for up to 12s and 20 amps, which is very high amps for bec i am told. anyway, all my fans are 6v. i do have 12v fans too but currently my build makes use of 6v fans. my servos are the hpi sfl-30mg 1/5 size for steering and for brake i have available a futaba s9157 and a jr9100hvt. the jr is capable of using 7.4v input but the steering servo can only go up to 6v so i will probabaly use the fut s9157 as it is rated at 425oz at 6v and the jr is 403oz at 6v.
is it possible to run 7.4v to one servo and just 6v to the other?
The HV servos were born from the rock crawler crowd, and they generally power the servo directly off a 2s lipo pack and use a BEC to give 6v to the rest of the electronics.
So, if you run a 2s receiver pack you could power your HV servo and then use your new BEC to power everything else. (BEC paralleled to the HV servo off the 2s)
To directly power the HV servo just run the + and -of the receiver plug directly to thhe 2s pack. Run the third wire (the signal wire) in the receiver plug to the receiver like normal.
KaztheMinotaur
KaztheMinotaur's Avatar
09.24.2009, 06:09 AM
I'm still hanging in there. I got a new to me truck last week so I've been busy with that.
I got my battery mounting plates mounted last night. I need a tap to make holes in my new motor mount plate. I should have time this weekend since that wife and kids are going back home to visit her uncle.
Ryu James
Ryu James's Avatar
09.24.2009, 04:58 PM
hey all,
so i am going to be using the castle bec to power the esc and reciever. but i have a small 2s 1350mah lipo that i want to use strictly for my 6v fans. how would i hook this up? do i just connect the batter directly to the fans? or maybe connect to a switch harness and then the fans? or do i need some type of resistor or something like with led's?
Jammin SCRT10 Neu 1512 1y
redshift
RC-Monster Square Tube
redshift's Avatar
09.24.2009, 05:11 PM
You'll need a gyroscopic thermocouple, and a passive resistor.
Direct or switched is fine. When will we see this thing in action??
florianz
09.24.2009, 05:12 PM
you don't need a seperate lipo pack. well, you can do if you want, they have 7,4 volts, which means good cooling with the 6v fans, no problem at all for sure.
or, you plug the cable for the fan into the receiver. there you get, depending on the ubec/bec, about 5 or 6 volts. if the bec is powerful enough for the big servo, don't worry about the fans. just don't plug the 6v fans onto 10s...
Ryu James
Ryu James's Avatar
09.24.2009, 05:27 PM
thanks guys. and you will see this in action soon...very soon. i stopped by the machine shop today and they were working on my hubs. in fact, they are probably done now and i can go pick them up so i can get my brakes installed this weeked too. i am gonna get the esc and bec all hooked up right now and ready to go and then start working on the brakes tonight. my buddy has a killer hi-def camcorder and will shoot the vid. so if he is available this weekend we should see some action. i am crossing my fingers.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.24.2009, 06:20 PM
SWEET!... luckily you have a buddy who works at the machine shop... It's going to be awesome seeing urs and Kazs' video....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Ryu James
Ryu James's Avatar
09.25.2009, 12:38 AM
yeah, i was thinking of starting a new thread. we'll call it the "Official thread for 1/5 Redcat Rampage Brushless Conversions" and all of us post some pics and vids of our final rides in there. and i am sure we will see more in the future. its such a great 1/5 to convert cuz its affordable. i am into mine about the same as it cost me to do a nice 1/8 buggy or truggy. what do you guys think?
big greg
09.25.2009, 12:47 AM
have you got the esc to power up yet?
KaztheMinotaur
09.25.2009, 06:10 AM
I'm feeling the peer pressure now...
I worked on mine last night though. I go the wires and bullet connectors to the ESC.
Ryu James
Ryu James's Avatar
09.25.2009, 12:10 PM
well my plan was to get the esc all hooked up tonight since i have the bec and everything now but since my machinist finished the parts for my hubs i decided to work on the disc brakes instead. here are some pics. tomorrow will be esc day and test run without brakes. i need to order a couple of parts to finish up the brake system. probably gonna be another week to get the brakes finished but i will try to get a video before then. there are a ton of small, time consuming, mods needed to make these disc brakes work.
to make the disc brakes work i had some small aluminum blocks made that attach to the hubs and then the calipers attach to them. a few pics.
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Ryu James
Ryu James's Avatar
09.25.2009, 12:16 PM
gitter dun!!
brushlessboy16
brushlessboy16's Avatar
09.25.2009, 12:31 PM
so did you ever get that controller working?
florianz
09.25.2009, 01:53 PM
looks good
great built!
aqwut
aqwut's Avatar
09.25.2009, 04:37 PM
Brakes looks cool man.. Should be plenty of stopping power...
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
