Shark413
Shark413's Avatar
09.25.2009, 04:41 PM
Originally Posted by superlapS15 View Post
How is the Tekin motor holding up? Particularly temps- it sounds like you've had scorching heat there which would contribute to the higher temps (180 and most recently up to 175).
I'm currently running a Losi 8ight (1512 2D, 4S, Modified MM/BEC, 12/46) and I've just started converting an 8ight 2.0. I plan on going 6S/low kv and so far a Tekin 1400/MMM combo seems the best option (I've already got two MMM, and I'm not wanting to try the RX8 yet). Other than the rotor issue, the Tekin motors seem to be performing well under race conditions.
I've enjoyed reading the write up you've posted here- I hope there are more updates to follow! Thanks for all the info so far!
I think may be the motor was just bad, or didn't have enough torque for my setup. I have since been running a 2200KV MMM motor (truggy size) and the temps are great. I am running a Tekin 2000kv motor in my 8ight 2.0 truggy and it has been running great and no issues with the rotor. I also just recieved some of the Castle blower fans, and it fits righ on the motor and under the body with no clearence issues. It should help keep the temps down on those super hot days here in Socal.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
superlapS15
09.27.2009, 06:32 AM
I get the impression that rotor failures aside, the Tekin motor is far more reliable than the Tekin RX8 ESC.
My main interest in the Tekin motors lies in the low KV options available and the 4mm mounting holes. Neu has low KV motors, but I would be stuck with 3mm holes (I'm not going to try to tap 4mm holes) and the wires exiting out the rear of the can have caused some hassle in the past- similar to your problem with melting/splitting the wire covering, I melted all three! At the moment, my Neu 1512 2D is still holding together (despite some heat issues a few weeks back) and will remain in my 8ight, and the MMM/2200 combo I have lying around will go into the 8ight 2.0. When I try 6S/low kv, I will probably get a 1400kv Tekin motor to test and see how it performs, at least until Castle release a low KV motor (with 4mm holes, just in case someone is reading this!!! )
Temperature wise, I'm heading into summer here in Australia (South East Queensland) so any motor/esc is going to have a tough time. Generally though, it is the motor that runs hot for me, with the ESC only running slightly hotter in summer (10-15F hotter). I went to the track today to try a few ESC changes on my modified MM but a damaged wire/ripped off connector ended the day after only one lap of qualifying- I was hoping the changes I made to the braking power (decreased power, steeper braking curve with full braking from 50%) would help the 1512 2D run a little cooler. It seemed to run cooler on my track, but it really requires testing on a large track to confirm any improvement.
I did see that Castle have released their motor fan, but I'll be interested in first managing temps with my existing setups, then perhaps adding a fan for additional cooling and reliability. If I can get both my motors to stay under 150 after a 10 minute qualifier (including 2-3 mins warm up) I'll be quite happy. Adding a fan would then provide an additional measure of protection for the hotter months of the year.
You mentioned torque in your post- I'm curious to see how the 2200kv performs compared to the 2550kv Neu, the CC motor being a longer rotor/magnet/can design. I'm not really after speed, but I want to always have that 'punch' that electric provides. It may well be the case that the longer can motor provides that 'punch'/torque with less current draw, hopefully improving temps and runtime.
