Qball76
03.13.2005, 12:52 PM
Originally posted by gorillamaxx
The mount was originally designed to lower the cg of the motors. I still think the best set-up (even for a single) is as low as you can. The center will work, but in this location, you're putting all the weight furthest from the support points.
Good jod on explaining the rod idea Mike :L:
I know we have a few guys on this site that are running large single motors on center - it would be good to get their input here.
Thanks
I've been running the Novak HV in the on center position up top and the result has been partially stripped spur gears. I've got a 9L on the way and I plan on lowering it down with the controller on the opposite side. At first I assumed that by putting the motor on center I would get better balance, but I don't think you gain enough to make it worth the headache of stripping spur gears on hard landings.
