killerlst
09.30.2009, 12:20 AM
OFNA Jammin X1-CRT
mamba max 2200 motor and speed controller 5 cell 4000 mah 35c lipo battery 75mph on the rear wing! hoping to get some vids up
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.30.2009, 12:54 AM
I've hit 78mph in my Revo running 6s G3 lipo turning a 1512/3D(1700kv), at least that is what the iPod 'dyno' app. reads, not radar confirmed. It was faaast, and yes, the front end looked like it was going to go air born once up to speed.
PBO
RC-Unobtainium
PBO's Avatar
09.30.2009, 06:49 PM
I've got some buggy diffs I'm about to drop in & some new foam tyres...
I think with what I have in gears & parts 100mph is possible?
How far does the general consensus allow modifications because aero is an obvious area of improvement?
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 44
Pinion Tooth Count: 25
Total Voltage: 22.2
Motor KV: 2700
Tire Diameter (inches): 5
Tire Ballooning (inches): 0.01
Motor Current Draw: 150
Motor Coil Resistance: 0.004
Spur/Pinion Ratio: 1.76 : 1
Total Ratio: 5.82154 : 1
Tire Circumference (inches): 15.77 inches (400.58 mm)
Rollout: 2.71:1
Total Motor Speed: 58320 RPM
Vehicle Speed: 149.61 mph (240.33 km/h)
Effective KV Value: 2627.03
KT constant: 0.5 oz-in/A
Motor Torque: 0.39 ft-lbs
Final Torque: 2.28 ft-lbs
Final Power: 3330 watts (4.5 HP)
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
nitrostarter
nitrostarter's Avatar
10.01.2009, 10:17 AM
Just some food for thought for you guys running a 2.5 or 3.3 Revo converted and want to gain speeds or is currently limited by gear selection: Get a Slayer tranny. The overall ratio is lower than the Revo and has the same clutch application to lock in 2nd gear. This should open up some gears and allow higher top speeds provided you have the power there.
N. Rustler conversion
riverat1540
riverat1540's Avatar
10.01.2009, 10:29 AM
Originally Posted by killerlst View Post
OFNA Jammin X1-CRT
not to be an ass but how are u verifying ur speed, i doubt any one running a crt x1 is hitting those speeds with that huge spur limiting pinion options, plus this would mean a 75mph truggy is running on 5s and yet at a wheelie with stock spur. proof needed
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
riverat1540
10.01.2009, 10:33 AM
the crt x1 already has buggy diffs in it so if u need more gearing options nitrostarter drop to a 46t spur.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
PBO
RC-Unobtainium
PBO's Avatar
10.05.2009, 05:21 PM
I had a very quick run as a storm was coming...
I've lowered my 8T & was conservatively geared at 44/24 with 100k in the centre diff...2 "passes" (the street is only 200ft long) with the throttle wound way down 80/140% easy to drive & quick enough...2 "passes" at 140/140% & "OMFG what have I created"...then the heavens opened up
Next effort will be at a suitable location, without rain & will include GPS/video
Losi 8ight-T
nitrostarter
10.05.2009, 05:41 PM
Me like this...
PBO
RC-Unobtainium
PBO's Avatar
10.12.2009, 01:53 AM
I think I need a mid rear drive shaft bearing or smaller batteries!
2 x rear shafts bent out of round when I get up around 60-70% throttle, the sound is awful. I was thinking about an alum mount (could combine a rear motor mount for the RCM mount) & fixed delrin bearing, mid shaft to stop the problem. I'm not sure what else to do...everything else seems fine, it seems like it's just the load through the shafts. I'm running 6S G3 VX 6500
Anyone else had this problem?
Losi 8ight-T
Bump..
bcltoys
Bump.. - 11.25.2009, 08:51 PM
Well what are the speeds now.
PBO
RC-Unobtainium
PBO's Avatar
11.26.2009, 10:28 PM
I've made no real progress, I've moved house & a few other things...
I have however made an alloy pillow block for the rear centre shaft, bought 2 x new rear shafts and bearings. I'll be running soon
Losi 8ight-T
LanceD
02.25.2010, 05:17 PM
Other Ratio: 1
Total Voltage: 22.2
Motor KV: 2700
Rollout: 2.71:1
Where did you get the foam wheels from ???
PBO
RC-Unobtainium
PBO's Avatar
02.25.2010, 05:28 PM
They're ATS brand which are made in Italy
Losi 8ight-T
