I've got some buggy diffs I'm about to drop in & some new foam tyres...
I think with what I have in gears & parts 100mph is possible?
How far does the general consensus allow modifications because aero is an obvious area of improvement?
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 44
Pinion Tooth Count: 25
Total Voltage: 22.2
Motor KV: 2700
Tire Diameter (inches): 5
Tire Ballooning (inches): 0.01
Motor Current Draw: 150
Motor Coil Resistance: 0.004
Spur/Pinion Ratio: 1.76 : 1
Total Ratio: 5.82154 : 1
Tire Circumference (inches): 15.77 inches (400.58 mm)
Rollout: 2.71:1
Total Motor Speed: 58320 RPM
Vehicle Speed: 149.61 mph (240.33 km/h)
Effective KV Value: 2627.03
KT constant: 0.5 oz-in/A
Motor Torque: 0.39 ft-lbs
Final Torque: 2.28 ft-lbs
Final Power: 3330 watts (4.5 HP)
