kneedeeppow
is lovin life brushless
kneedeeppow's Avatar
10.02.2009, 10:13 PM
Originally Posted by riverat1540 View Post
if u get a 5s pack and gear down u would have a cooler running system, more on demand torque and extended run times, u will have a bit more weight but make up for it in power, alot of people here are running 5s in their truggys with good results
to gear it down do i change pinion and spur or just one of them?
associated rc8t..........e
tamiya f104pro,r,w.f103gt.tb02,ta02
nuova faor sf501
avatar is pic of what our cat does with empty boxes left over from rc purchases
10.02.2009, 10:18 PM
pinion is all you need to change. Run it with say a 15 t to start and constantly check temps...and then adjust gearing accordingly...in case you haven't see this...this is a great guide
Although not always true, a rule of thumb is:
Hot motor, cool controller, cool batteries = undergeared
Cool motor, hot controller, hot batteries = overgeared
Warm motor, warm controller, warm batteries = happy components
Hot, warm, and cool vary as well, so here's another general rule:
Hot for a motor = generally over 160F (71C)
Hot for a controller = generally over 150F (66C)(or "thermal" range for the controller)
Hot for batteries = generally over 150F (66C) for nimh, 130F (54C) for lipo
Warm for a motor = generally 100F (38C) through 150F (66C)
Warm for a controller = generally 100F (38C) through 130F (54C)
Warm for batteries = generally 100F (38C) through 130F (54C) for nimh, ambient temp through 120F (49C) for lipo
Cool for all components = generally ambient temp and up to 10 degrees F (5.6C) more
kneedeeppow
10.02.2009, 10:20 PM
are you running a 15t on the factory spur gear that runs in a nitro mbx5t?
nuova faor sf501
