10.02.2009, 10:18 PM
Originally Posted by kneedeeppow View Post
to gear it down do i change pinion and spur or just one of them?
pinion is all you need to change. Run it with say a 15 t to start and constantly check temps...and then adjust gearing accordingly...in case you haven't see this...this is a great guide
Although not always true, a rule of thumb is:
Hot motor, cool controller, cool batteries = undergeared
Cool motor, hot controller, hot batteries = overgeared
Warm motor, warm controller, warm batteries = happy components
Hot, warm, and cool vary as well, so here's another general rule:
Hot for a motor = generally over 160F (71C)
Hot for a controller = generally over 150F (66C)(or "thermal" range for the controller)
Hot for batteries = generally over 150F (66C) for nimh, 130F (54C) for lipo
Warm for a motor = generally 100F (38C) through 150F (66C)
Warm for a controller = generally 100F (38C) through 130F (54C)
Warm for batteries = generally 100F (38C) through 130F (54C) for nimh, ambient temp through 120F (49C) for lipo
Cool for all components = generally ambient temp and up to 10 degrees F (5.6C) more
kneedeeppow
is lovin life brushless
kneedeeppow's Avatar
10.02.2009, 10:20 PM
are you running a 15t on the factory spur gear that runs in a nitro mbx5t?
associated rc8t..........e
tamiya f104pro,r,w.f103gt.tb02,ta02
nuova faor sf501
avatar is pic of what our cat does with empty boxes left over from rc purchases
