what do now
what do now's Avatar
10.02.2009, 09:40 AM
The hyper 7/8/8.5 diffs (pro or rtr) have all the same gearing, 43/13. I have a bunch of them which I used on all my trucks.
Oh, I thought the Pro was like the Hyper 9/ST pro and was 43/10 or something. Sweet, will take another look.
Thanks.
what do now
10.05.2009, 08:41 AM
Great delivery by Addicted2rc, got these in the sale.
10.05.2009, 02:24 PM
Black is the new bling :)
what do now
10.05.2009, 02:27 PM
Well you know what they say "Once you go black........"
what do now
10.06.2009, 08:43 AM
Little more help.
I ordered 2 x Hot Bodies diffs from place in the UK since RC Monster doesn't have them. 2 more things I need.
Does anyone have a link to the drive cups needed for the diffs (out of stock here) and I'm not entirely sure what I'm looking for. I know its a 1/8th scale cup but any I have seen have 4mm set screw, not sure thats make a difference.
Also, what oil and grease does anyone use in the Hybrid/HB Diffs, I like some speed runs aswell as bashing, any links would be great.
Thanks Guys.
10.07.2009, 12:57 PM
Hot bodies drive cups are what I used, but finding them ( or any 8mm bore versions for that matter ) is somewhat tricky. I would hit up ebay to start with, search for 'hot bodies'... but specify in the toys & games section, otherwise... well, you can only imagine the results you will get. I'll have a look too when I get home- the work PC doesnt like alot of sites that use flash, and no way to update it withot being an Admin.
As for diff fluid- 7k front & 5k rear is a good starting point, or 5k front & 3k rear maybe if you prefer a bit more diff-action.
what do now
10.07.2009, 02:27 PM
Thanks, I did have a look around for 8mm bore drive cup but nothing. Plenty of drive cups but when your not sure what is 8mm and whats not it is like sticking a pin in them and there no chance any place will put a description with the them
Diff fluid, might go for the 7/5k so.
George16
Supermaxx
George16's Avatar
10.07.2009, 07:00 PM
I have some UE 8mm drive cups and a complete set of 6 spyder diffs that I can sell but I'm currently away on a deployment (US Navy).
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
10.07.2009, 08:31 PM
Shaz-zam:
http://cgi.ebay.co.uk/Hot-Bodies-C80...d=p3286.c0.m14
You need two of these, and some 4mm set screws to secure them in place (about 4mm long for the setscrews is ideal if my memory serves me correctly, though you can always grind them down if they are a little bit long). Some blue threadloc will come in handy too..
what do now
10.08.2009, 07:58 AM
Shaz-zam:
Excellent, Thanks a million.
That place on ebay only had one, but once I knew what I needed I did a serch and got a seller that had some and some sets screws aswell. So think I'm good to go now, think I have everything. Just waiting on the postman.
what do now
11.02.2009, 08:02 AM
Still waiting for shipment from the UK, damn, postal strike.
Quick question the below output shaft, anyone know where I can get a similar one as RCMonster want $26 to ship to Ireland.
http://www.rc-monster.com/proddetail...d=RCMdiffshaft
Thanks.
vader2728
E-Maxx Breaker
vader2728's Avatar
11.02.2009, 09:17 AM
Use the outer part of a Revo stub axle with the threads cut off... Lot cheaper... Found out after makin the investment for the RCM shafts...
So that's what all the fuss was about...
what do now
11.02.2009, 11:03 AM
Oh wow, part #5454, great idea and they work?
Thanks for the info.
vader2728
E-Maxx Breaker
vader2728's Avatar
11.02.2009, 11:10 AM
Got this idea from George16 (Lito)... Ask the Maxx guru, he will know for sure... I havent done it yet, but I have the parts on hand to convert another set of LST diffs to work in a Maxx...
what do now
11.02.2009, 11:16 AM
Excellent. thanks
