Freezebyte
10.11.2009, 10:56 PM
Eh don't follow - On a crawler you need and run with 100% drag break...
I guess im confused now also. What exactly is broken according to you on the MMM?
Finnster
KillaHurtz
Finnster's Avatar
10.11.2009, 11:15 PM
You want the drag brake to fully engage off throttle if you are crawling to hold you where you are. You don't want to go rolling away.
Freezebyte
10.11.2009, 11:56 PM
Oooooohhhhh
10.12.2009, 12:38 PM
Drag brakes Patrick - Did it make the new version?
TexasSP
Something, anything, nothing
TexasSP's Avatar
10.12.2009, 01:43 PM
A good drag brake makes or brakes a crawling ESC for sure. Thanks for the castle link update so I don't hve to pull my ESC out anymore.
www.cubicle101.com
brushlessboy16
brushlessboy16's Avatar
10.12.2009, 02:01 PM
I like the usb feature.. just put the esc in a place where you can access it
Freezebyte
10.12.2009, 03:20 PM
I'm not sure I get that, iv'e always just plugged the ESC into the adapter then into the computer via USB
bruce750i
bruce750i's Avatar
10.12.2009, 03:48 PM
The Mamba Max not the Mamba Monster has a mini USB port on the side of it, No castle link was needed.
Finnster
KillaHurtz
Finnster's Avatar
10.12.2009, 05:27 PM
I've had my MM in about 5 different cars, and only in one of them was I ever to place it where I could get to the port. The update will be welcome.
OTOH, I want to trade it in for a MMP. :)
etc1006
10.12.2009, 07:07 PM
Did the change to the MM allow it to work w/ Vista 64 bit? I did hear they were trying to do something throught the chip instead of the USB for 64 bit. If not seems like a waste of time to me.
10.12.2009, 08:53 PM
It works on Vista 64! i've done it!
You have to flash the MM on XP or vista 32 first - then you are good via castle link - YAY
etc1006
10.13.2009, 08:30 PM
Flash? I did use my ex's laptop that had xp to upgrade/program it earlier in the summer. But I'm not getting any response using my 64 bit desktop. It sees the usb connection but not the esc. Still tells you to use the usb in the mm.
Freezebyte
10.13.2009, 09:52 PM
Ohhhhh....
Freezebyte
Odd, mines worked on 64 bit Vista since day one.
10.13.2009, 10:21 PM
You have to upgrade the MM ESC first on XP and then you can use Vista 64...
Freeze - you have a MMM I'm talking about the MM
