10.17.2009, 09:17 PM
the tekin rx8 doesn't include wires for the battery? I got mine without them, only motor wires. And couldn't find anywhere in the manual a instruction on where should i attach the sensor cable support.
10.17.2009, 09:36 PM
CHeck there website. and I got enough wire for everything...
http://www.teamtekin.com/manuals/RX8-T8-Mounting.pdf
THE Paranoid Android
10.18.2009, 11:58 AM
I got some new rotors off my uncle (who was sent buggy rotors, not truggy rotors), so was able to race this weekend. I had my new slipperential to try, which went together perfectly.
I ran an XB808, 46T spur, 17T pinion, 1700kV T8 on an RX8. 5S 5500mAh 35C Hyperion. Slipper was fairly loose as the track was dusty and had little grip.
I qualified 5th overall, only my pinion came off in round 3, meaning the run was useless. I decided not to change my rotor for the final, just to see if it would last. Even with a run-through-the-pit-lane stop-go penalty (as I didn't have to stop for a battery change), I finished 4th, only about 7 seconds off 3rd after 20 minutes.
With a combination of the new Tekin rotor, and (probably more importantly) the slipperential, I've finished my first ever final with the Tekin (all the rest have been DNFs). This is the best result I've had all season with the Electric, since my second meeting with a battery change, a Medusa motor, and an MMM.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
10.18.2009, 01:35 PM
Congrats chap!
How did the Slipperential make the difference do you think?
10.18.2009, 02:22 PM
It makes the car far easier to drive out of corners, particularly on loose/low grip tracks (like my local track). It also seems to help the car over ruts and bumps, calms the low end down, and makes it generally more forgiving. It also seems to add rear-end grip.
10.18.2009, 03:29 PM
Sounds good, I have very bad memories of the slipper in my old savage
Do you think it will aid durability with the ESC/Motor to lift some strain off them long term?
10.18.2009, 04:25 PM
I think it will actually, it certainly made my Tekin last all day!
10.18.2009, 03:38 PM
Yep well done Marv,you stuck with it and now,hopefully its sorted,gonna fone Tekin tomorrow about them sending the wrong rotors(another weekend racing missed  )getting a bit annoyed and impatient now.
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
