Guelph, Canada, eh!
09.27.2009, 11:13 PM
Well I changed what I called ''the last CD I will make'' for my ERevo. I used Axial posts instead of the Kyosho ones. The Kyosho ones are well suited for a CD made for the nitro Revo tranny because they are 5 mm in diameter and they fit better in the small 28 tooth gear that has to be used. But they have to be cut to the right length. The bigger TRA3985X 33 tooth gear of the ERevo CD works very well with these 7 mm diameter posts from Axial and the posts don't have to be modified in any way. But the output gear is drilled with a 9/32'' bit to slip over the Axial posts.
i pwn nitro
10.05.2009, 05:49 AM
just ordered the parts to do the LST diff conversion.
going to differ it a little bit by using the OTHER black outdrive gear from the revo and going to make custome posts on the lathe.
10.05.2009, 12:40 PM
Well I got the hybrid center diff installed no problem. I started to do the F/R RCM hybrid installs but I'm having issues, so I'll probably just keep the stock F/R diffs in so I can get some driving in and then work on the RCM hybrids over the winter. I ended up filling the center hybrid up with 50k silicone oil. I'll report back once I get some driving in, maybe even later today if the weather holds. I want to try to unleash the punch control on the MMM a bit more and see how the center hybrid diff handles it.
i pwn nitro
10.05.2009, 04:35 PM
you dont understand how close i was to getting a losi smart diff for conversion, same principle just a little more $.
hope to have smart diffs all round one day i think
10.06.2009, 12:54 PM
I almost tried an Ofna Spyder diff. Might still do that, or look at a Torsen diff.
10.07.2009, 12:29 PM
I've seen quite a few people mention the torsen diffs dont handle BL power all that well, plus they work the opposite way to a normal diff; instead of sending excess power to the fronts to prevent wheelies, they send all the power to the rear wheels (if used as a center diff)- not good for handling...
i pwn nitro
10.15.2009, 05:19 AM
well my LST diff turned up.
my mate got a losi smart diff for xmas pressie to himself for later conversion.
i reckon we'll put that in the front depending on how much we like the LST center diff.
i'm not going to use the carbon fibre on mine as the gear already has one side blocked over with plastic, this is what the carbon fibre would do in the other setup.
i'm going with this setup...
http://s177.photobucket.com/albums/w...t=losi_cd2.jpg
my only concern is that it will be a pain to dissasemble.
10.17.2009, 03:07 PM
Is anyone intersted in selling a 1/8 center diff that will fit a nitro (3.3) tranny ?
I dont have the skill, stuff or time to do one myself.
10.17.2009, 03:39 PM
have thouse people tired them?
i have torsen diffs in 3 of my brushless conversions (2 buggys and a truggy)and all of them show very little wear
i think the people who are haveing problems are either building them wrong or not changeing out grease often enuff
and as for putting power thrugh them, im running 5 and 6 cell, when set up right they work the way they should, my 8ight will lift the wheels about 2 inches for only a second when leaveing the line but its a hell of alot faster launch than balloning the front tires.
Originally Posted by Semi Pro
Originally Posted by BrianG
Guelph, Canada, eh!
10.18.2009, 11:01 AM
That set up is a pain to assemble and disassemble. I suggest you go with the last system I did in post 46.
Guelph, Canada, eh!
10.18.2009, 11:04 AM
I could part with the ''CowboyRay'' CD I have. I updated it with shafts to run the rear brake so it's ready to go inside a 3.3 Revo tranny. PM me if you're interested.
i pwn nitro
10.18.2009, 04:37 PM
i began building it that way, but i decided yesterday to change the plastic gear.
rather than using the solid tranny 5 spoke gear, ive switched to the trx revo center diff gear.
that will make things a little easyer for me
more even screw spacing then.
how on earth did you drill holes in your "cap" cause i actualy DE-hardened mine, heated it up then let it cool in cement dust for 24 hours. i can drill mine now.
10.18.2009, 06:25 PM
That cd w/the carbon fiber is real nice...I wish I had the skill to perfectly cut a perfect circle like that! Well done! =)
10.18.2009, 06:59 PM
As previously posted I actually had my local machine shop tell me they couldn't even do it. Ended up spot annealing and using a pure carbide bit as suggested by mistercrash and it was a piece of cake. I'm kind of interested to see how it would be drilling an un-annealed cap, just to compare it and see how much the annealing helped. Also used a cobalt tap for the threads, but depending on what design you follow you might not need to tap at all.
Guelph, Canada, eh!
10.18.2009, 07:45 PM
I used carbide drill bits and a carbide counter sinking bit like SC did.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
