shaunjohnson
i pwn nitro
shaunjohnson's Avatar
10.18.2009, 04:37 PM
Originally Posted by mistercrash View Post
That set up is a pain to assemble and disassemble. I suggest you go with the last system I did in post 46.
i began building it that way, but i decided yesterday to change the plastic gear.
rather than using the solid tranny 5 spoke gear, ive switched to the trx revo center diff gear.
that will make things a little easyer for me
more even screw spacing then.
how on earth did you drill holes in your "cap" cause i actualy DE-hardened mine, heated it up then let it cool in cement dust for 24 hours. i can drill mine now.
  Send a message via MSN to shaunjohnson
simplechamp
simplechamp's Avatar
10.18.2009, 06:59 PM
As previously posted I actually had my local machine shop tell me they couldn't even do it. Ended up spot annealing and using a pure carbide bit as suggested by mistercrash and it was a piece of cake. I'm kind of interested to see how it would be drilling an un-annealed cap, just to compare it and see how much the annealing helped. Also used a cobalt tap for the threads, but depending on what design you follow you might not need to tap at all.
shaunjohnson
i pwn nitro
10.19.2009, 02:07 AM
if un-annealing means un-hardening then it was fine to drill with.
just heat up till red hot, then cool as slowly as possible for 24 hours (cement dust works a treat) and then drill with a standard drill bit.
edit: first LST diff in final stages now, i ended up using the traxxas center diff gear on the LST diff instead as that is what i had on hand. will fill with 100k oil then go try and kill it on 6s
shaun
simplechamp
10.19.2009, 06:00 PM
shaun
Annealing is softening the metal. I did spot annealing at the suggestion of some guys on a CNC forum. Yes, the metal drills very easily after annealing.
What I was saying is I would like to compare drilling the annealed metal to drilling the stock un-altered hardened metal, and see just how much the annealing actually helps.
I don't think you need to wait 24 hours and use the cement dust. Cement dust or not the metal will be cooled to ambient temp within 15-30 min. at most
shaunjohnson
i pwn nitro
10.20.2009, 02:13 AM
i chose cement dust from personal experience, i have had a larger item kept red hot for hours on end by putting it in cement dust as it has good insulation capabilities.
shaun
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
10.18.2009, 07:45 PM
I used carbide drill bits and a carbide counter sinking bit like SC did.
No brain, no headaches.
