10.21.2009, 03:55 PM
You could probably find a better price if you look around. I just knew Tower had them so I could show you what you needed with pics.
J57ltr
10.21.2009, 04:15 PM
If you are inclined you can make your own temp probe using a Rx harness cable and a 10K ohm NTC thermister. I ended up making 2 extra ones for about $2 buying the parts and the temps are within 1 degree of each other.
Jeff
