10.21.2009, 04:51 PM
The endbells are press-fit and some kind of adhesive is used. I had a 36-50 endbell start to pop off, but when I took it apart I found that there wasn't enough material to put even the smallest screws in. The 80mm motor had a lot more area to use screws, not sure how much there is on the 60. Anyway, on my 50mm motor, I cleaned off all the old adhesive and used JBWeld. Hasven't had a problem since, but haven't run it much since then either.
