Byte
10.27.2009, 06:20 AM
I know his stuff. I got his 2-speed 5mm for my LST.
The motormount from him looks good, but it won't fit an Bigmaxx and I think it's a bit overprised.
I use the stock LST1 wheels/tyres.
@Bondo, If I buy those HD axles, I also need the LST2 hexes right? The LST1 hexes won't fit I think...
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.27.2009, 07:49 AM
The mount is expensive yes, but worth every penny due to being well made.
If it doesn't fit a Bigmaxx you should email him and ask, he might be able to accomodate ?
If you can make HD mount yourself as mentioned in a prior post of yours,do it ! Save some $$
LST2 17mm hubs
http://cgi.ebay.com/LOSI-LOSB3516-WH...item3ef4b31c62
20mm hubs,stock LST2
http://cgi.ebay.com/Team-Losi-LST-XX...item4a9ba96dd6
23mm hub that will fit LST2
http://cgi.ebay.com/NEW-CEN-GST-7-7-...item4838024b91
Byte
10.27.2009, 07:58 AM
LST2 17mm hubs
Well, my LST wheels got 14mm hexes lol... I was looking at the LST Upgrading kit, in that kit there are LST2 rims. But will those LST2 rims fit my LST1 tyres? If not than I also have to buy new tyres...
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.27.2009, 08:07 AM
I beleive they will !
I like the original LST tires, great grip and light.
Then shoot for the 20mm hubs
Byte
10.27.2009, 08:31 AM
Ok. Thank you for your help Bondonutz!
drkdgglr
10.27.2009, 09:25 AM
the bigmaxximum should fit the tdracing mount. according to this pic, the plet has a diameter of 43mm, 25mm spacing of the mounting holes which are m3.
send him an email with the drawing of the motor. he might have to adjust the mount because of the 3mm flange. I had a flange on my neu 1521 and ruined the front cap. A new cap is one the way with the flange sanded off.
and he will ship over the pond...
drkdgglr
10.27.2009, 09:55 AM
Hey James,
I mentioned the boss/flange thing in my post....
On his site he says he can do custom mounts if you give him the right dimensions:
A manufacturers drawing is usually best if you can get one. I will try to make this mount work for your motor.
edit: the first run with my LST XXL sent my esc up in flames. shit happens I guess
