riverat1540
riverat1540's Avatar
10.27.2009, 05:27 PM
lst or muggy diffs can handle it within reason
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.27.2009, 05:41 PM
(4) 1527 1.5d's are NOT within reason
Hey FBE, what voltage you plan on running, What packs ETC ?
Curious to the layout of the drivetrain for 4 BL motors ??
JThiessen
JThiessen's Avatar
10.27.2009, 06:09 PM
I was actually just at the hobby store and was looking at the 5B on the counter to see what parts I could possibly use off it. Unfortunatley, I didn't look at the brakes at all. I did kinda snoop around the rear diff to see if one could use those in a 4WD application - but unless you were to build a bulkhead for it, it can't be mounted upside down. Steering components looked like a possiblity though.
Edit:: BTW, HOLY S#*$($! "Beast" is not an appropriate noun to use for what your looking at doing......
fatboyelroy
10.28.2009, 04:47 AM
Thank you guys for the input and enthusiasm. I will probably end up using this brake set or these with some modded aluminum hubs and axle carriers.
I am not sure if I want to use a123s or lipos. I want to keep it at around 6s.
I will be using an E-maxx aluminum flm tranny case and gmaxx single speed conversion with a set of ultramaxxed Gen III metal gears. And yes an upgrade to the diffs is a must.
