florianz
11.07.2009, 01:36 PM
Originally Posted by freddy1 View Post
thanks for posting up info!
should i keep the 2 speed?
or go center diff?
its just for bashing some pretty hardcore bashing
i heard you cant land on the gas it makes the gear strip is that right??
im also looking for a brace i have been looking at rc visions braces
there a lil pricey for a lil 7050 T-7 Aluminum, rod. im going to try to make my own. or maybe even get one made
I think you should go for a center diff. the CD are a bit smaller then the 2gear, a center diff is about 35mm "thick". so you have to get that solved.
and you need a rod to avoid bending, be sure that ist's a quality aluminium. those chassis aren't the stiffest ones, you can't compare that to a mugen or los or whatever. I just converted a budget truggy, and took a tintianium rod to stiffen the chassis.
you could get gearing problems with 2200 on 6s. I would go for the tekin w. 1700kv on 6s.
freddy1
11.07.2009, 02:12 PM
Im pretty sure can make a simple brace just like the rcvisions
would the RC-monsters center diff work????
for now I'm going with a ezrunn system..
