Mamba Max on 5S in a truggy?
The Dan
The Dan's Avatar
Mamba Max on 5S in a truggy? - 11.07.2009, 10:49 PM
I've been dying to breathe life into my rolling RC8T for weeks now, but I'm on a budget. I've got a venerable old MM ESC lying in wait for it's next assignment, complete with a fan and Castle BEC. It never let me down running 4S in my buggies, so I'm thinking about slapping a Feigao 10XL (~1700kv, 66A) behind it and running Zippy 5S packs. Have any of y'all played with running a MM on 5S before? In theory it should work without problems, having even less amperage to heat it up. Just wanting to ask the experts.
11.07.2009, 10:56 PM
The newer mm I believe will not handle 5s w/out some serious mods. and even then it was having trouble arming. Hence the reason for the mmpro which can do up to 6s and has the same basic foot print as the mm.
Snipin_Willy
Snipin_Willy's Avatar
11.07.2009, 11:09 PM
Depends greatly on which variation of MM you have. Check the caps; if you see they are 25v cap then I wouldn't try it.
jas21373
11.08.2009, 02:13 AM
yeh mate ,I've had mine on 5s for a long while and have mates also running 5s with the MM esc ,just uprade the wires to 12g wet noodle,should be sweet then.
Matthew_Armeni
Matthew_Armeni's Avatar
11.08.2009, 04:07 AM
If you're using motor brakes 5s is the highest I'd go due to voltage spikes. I'd also add some extra caps to be safe and a fan. If you run mechanical brakes, 6s will work on the MM with just a fan. An external BEC is a must of course on both.
  Send a message via AIM to Matthew_Armeni
11.08.2009, 06:30 AM
MM is not spec'd for 4s, let alone 6s; anyone running 6s is walking on water, if you know what I mean.
Do it right, buy the MMpro.
jas21373
11.08.2009, 07:19 AM
I've try 6s on a MM ,it doesn't except the voltage.......wan't start up
sikeston34m
sikeston34m's Avatar
11.08.2009, 08:15 AM
+1 on this.
I have the MM Pro and couldn't be happier with it. It already has a fan, and is smooth as butter.
If you ever have the desire to run a sensored motor, the MM Pro can do that too.
The Dan
The Dan's Avatar
11.08.2009, 05:28 PM
Thanks for the input, guys.
nitrostarter
nitrostarter's Avatar
11.08.2009, 07:35 PM
Why not get a MMM and be done with it?
N. Rustler conversion
The Dan
The Dan's Avatar
11.08.2009, 08:42 PM
Because I'm on a budget, and I have more faith in my trusty MM than a MMM. Although now that I've thought about it more, I'm pretty much settled on a 4S/8XL setup rather than a 5S. I ran 4S/8XL in my old E-Revo and it was cheap awesomeness.
My MM has the 25v caps.
fastbaja5b
fastbaja5b's Avatar
11.08.2009, 08:55 PM
Mamba Max is a 3s ESC
running it on 5s =
Say Less, Do More.
Unsullied_Spy
Unsullied_Spy's Avatar
11.09.2009, 02:47 AM
4s is fine, but 5s is begging for trouble IMO. +1 for the MM Pro, they seem solid and are built to handle the voltage.
jsr
11.10.2009, 02:24 AM
I had a MM with external BEC on 4s in my truggy and it got HOT quick, even with a 40mm fan on it and another 90mm fan above it. I wouldn't run it over 4s. MM on 3s or 4s in a buggy is great, on a truggy, it can be tough on that little ESC. If you can keep it cool, then it will work fine on 4s. The problem is keeping it cool.
jas21373
11.10.2009, 05:42 AM
that would be the same as the ones I got ,Ive got the MM in both my Emaxx ,and my Hyper ST truggy.Both trucks run Medusa 2000kv motors 70mm and 80mm,the Hyper is geared 16/48 and the Emaxx 23/58 ,Emaxx runs
4s 4900mah and my truggy is on 4s 6500mah for track work and 5s 4900mah for bashing,both speedies have BEC's and 25mm fans on top.
I've never had any issues with either MM speedy(maybe I got two good ones..????),I also own a MMM V3 speedy on a 6s powered 1/8 onroad.
My advice to you is Just DO it, But keep an eye on your temps.........Fieagos run hot ,Why not look for a secondhand Medusa????
