Go Back   RC-Monster Forums > Support Forums > Team Tekin
info tekin motor T8 2250kv
galaxy76
info tekin motor T8 2250kv - 11.24.2009, 06:58 AM
WISH TO KNOW SOME INFORMATION for motor T8 tekin 2250kv:
- VOLT MAX = ???
- TEMPERATURE MAX = ???
- RPM MAX = ???
- PIGNON AND SPUR GEAR MAX FOR TRAXXAS E-MAXX OLD VERSION = ???
11.24.2009, 09:58 AM
use this calculator to estimate speed and gearing...it will also show you rpm's related to your chose gearing...http://www.scriptasylum.com/rc_speed/index.html
plug in the variable and it will help you out. As far as temps go..we all like to keep motor temps below 150. Not sure on max. voltage
Unsullied_Spy
Unsullied_Spy's Avatar
11.24.2009, 02:21 PM
I'd run it on 4s primarily, step up to 5s for when you need more power. I'm sure it could handle 6s but that's a lot of RPMs. Max temp is somewhere between 180 and 200 but I always stop running at 160 to stay on the safe side. I'd keep the RPMs under 45,000 but I'm sure the motor can handle more.
galaxy76
11.25.2009, 07:01 AM
X magman:
I do not scrptasylum. unfortunately it is not real.
X Unsullied_Spy:
tekin http://www.teamtekin.com/hotwire/ESC...up-sheets.html
says here max 4S lipo for 2000kv (2250kv) trugghy. I misunderstood?
Unsullied_Spy
11.25.2009, 04:25 PM
If they say 4s maximum, I'd stick to 4s maximum.
galaxy76
11.26.2009, 02:42 AM
I can not understand anything. look here http://www.rctech.net/forum/electric...ml#post6637024
What is the maximum voltage?
Randy Pike is what he writes?
or what is written in the site tekin?
galaxy76
11.28.2009, 07:21 AM
uppp
mocky
11.30.2009, 03:39 PM
English isn't galaxy76 strong suit but here are some tips if you can understand:
Max voltage: Possible to use 6s but not recommended for longevity of motor. 4s-5s is acceptable.
Max temperature: No more than 70C after 15 minute run
Max RPM: If you are worrying about this then you have other issues in your vehicle.
Gearing: Gear ratio will be DIFFERENT DEPENDING ON YOUR APPLICATION. This link will allow you to calculate top speed http://www.scriptasylum.com/rc_speed/_top_speed.html
For E-maxx I suggest start with max speed of 30mph. If MOTOR, ESC or BATTERY gets too hot then reduce top speed by changing gear ratio.
galaxy76
12.01.2009, 04:27 AM
grazie :)
