Unsullied_Spy
Unsullied_Spy's Avatar
11.27.2009, 02:03 PM
Any ideas on when these new motors will start shipping? I'm going nuts waiting for my 1717!
Duster_360
11.27.2009, 04:44 PM
Did anybody find out anything about mounting one of these? Size screws and hole spacing?? Will they mount in same place as the 2200?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
11.27.2009, 04:58 PM
Excellent Q ! +1
Unsullied_Spy
11.27.2009, 05:23 PM
Pretty sure it was said in this thread or another that it has standard spacing, 3mm (standard) screw holes, and a 5mm shaft.
Semi Pro
Semi Pro's Avatar
11.27.2009, 08:01 PM
so can we tap them to 4mm without voiding out warrentys ( and by we i meant people who know how to remove the end bell and use a tap and die?)
Unsullied_Spy
11.28.2009, 06:21 PM
Castle uses a good bit of common sense when dealing with warranty claims, if you tap the holes out and it fails as a result of something not related to the tapping it shouldn't be a problem. If you run the tap in, push through the ring protecting the coils, and into the coils you need to buy a new motor but as long as you don't cause the problem I don't think you'll have a problem with a warranty claim.
It was asked in this thread twice, but never answered. In the Black Fri thread SuicideNeil says its std 25mm spacing with 3mm screws from Castle's site, but I don't see it.
I'm on dial up right now so I am not taking the time to check the site again, but it doesn't make sense for them to release a motor aimed at our market with a odd sizing and spacing. It would be wise of them to make these motors bolt up like any other, I bought one without a doubt in my mind that it would bolt up to my RC-M conversion.
Duster_360
11.27.2009, 11:30 PM
