Originally Posted by Semi Pro
so can we tap them to 4mm without voiding out warrentys ( and by we i meant people who know how to remove the end bell and use a tap and die?)
Castle uses a good bit of common sense when dealing with warranty claims, if you tap the holes out and it fails as a result of something not related to the tapping it shouldn't be a problem. If you run the tap in, push through the ring protecting the coils, and into the coils you need to buy a new motor but as long as you don't cause the problem I don't think you'll have a problem with a warranty claim.
Originally Posted by Duster_360
It was asked in this thread twice, but never answered. In the Black Fri thread SuicideNeil says its std 25mm spacing with 3mm screws from Castle's site, but I don't see it.
I'm on dial up right now so I am not taking the time to check the site again, but it doesn't make sense for them to release a motor aimed at our market with a odd sizing and spacing. It would be wise of them to make these motors bolt up like any other, I bought one without a doubt in my mind that it would bolt up to my RC-M conversion.
