TexasSP
Something, anything, nothing
TexasSP's Avatar
12.04.2009, 05:33 PM
Originally Posted by Slowkrawl View Post
So far I have tried afro-engineering some tape around it which worked alright, but there was still some water on it.
I am so surprised no one else caught the wording above.........
www.cubicle101.com
Unsullied_Spy
Unsullied_Spy's Avatar
12.04.2009, 05:53 PM
I caught it, haven't heard that one before.
I would try putting it in a tupperware container and checking often to make sure it doesn't overheat. If heat is an issue then drilling holes in the bottom should let enough air flow through it to keep from getting too hot.
TexasSP
TexasSP's Avatar
12.04.2009, 06:17 PM
Well, in my experience it's a nicer version of a derogatory term. Maybe others see it differently.
www.cubicle101.com
brushlessboy16
brushlessboy16's Avatar
12.04.2009, 06:24 PM
It happens to the best of us. no harm done
HomeGrown
HomeGrown's Avatar
12.04.2009, 08:04 PM
8 mins?? oh lawd.. i watched it tho.. wonder if works for my MM?.. i never knew you could submerge a brushless motor.. interesting..
BL Pede, Integy aluminum steering linkages, aluminum shock caps, RPM camber links.
Never Replace Always Upgrade!
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
12.04.2009, 08:19 PM
Hmmm I may go to town with the plasti-dip on it and also figure a way to stuff a heat sensor off the dx3s in there to keep an eye on things? It should thermal first though...
V0RT3X
Muggy love
V0RT3X's Avatar
12.05.2009, 03:45 AM
Also see:
http://rc-auto.ru/forum/index.php?s=...ndpost&p=90095
bryan
bryan's Avatar
12.06.2009, 10:08 PM
PARK IT FOR THE WINTER.
Cartwheels
12.06.2009, 11:14 PM
Plasti-dip is easier to find but, isn't a conformal epoxy coating the correct stuff to use?
http://www.offshoreelectrics.com/inf...erproof-rx.php
Freezebyte
12.07.2009, 01:53 AM
No way in hell im gonna chance getting my $1000 Flux wet.
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
12.07.2009, 02:21 AM
Live a little! The waterproofed esc worked dandy, however the lipo's didn't like the cold so much! Live and learn.
Unsullied_Spy
12.07.2009, 03:20 PM
What happened to your lipos? I run in the cold all the time and have never had a battery problem. My fingers freezing up is the biggest problem
V0RT3X
Muggy love
V0RT3X's Avatar
12.07.2009, 03:27 PM
Would plastic sandwich baggies and zipties be sufficient for lipo protection? Once they reach their "operating" temperature they shouldn't mind being out in the cold.
I will also need this:
Unsullied_Spy
12.07.2009, 03:41 PM
If you're worried about getting them wet, I'd use a balloon and zip tie the opening. I leave my lipos indoors around 70 degrees so they're fairly warm when I start the run and usually only 80-90 degrees at the shrinkwrap by the end.
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
12.07.2009, 08:14 PM
Take a look at my "soo umm that can't be good" thread
