12.04.2009, 08:43 PM
Tell me about it- lack of upto date/ item specifc images has always been a pain in the r/c world, makes me have to 2nd guess everything I look at sometimes.
The last 2 pictures you posted especially make me think those are combos and not hybrids- the hole/ recess for the bearing to sit in should be exactly the same on each half - Im gonna assume when you tried fitting the bearings that came with your 1/8 diffs, one side was fine, the other isnt even close (not just a tight fit which is normal, but a good 1mm or more too big to fit)?
If thats the case, FLM should sort you out, but getting hold of them is a pain quite often. Just keep the emails civil to avoid them blanking you..
what do now
what do now's Avatar
12.05.2009, 06:54 AM
Thanks for the info.
And yes your right, one side is fine the other is way off.
Last night I managed to find the invoice that came with them, it doesn't say if its a Combo or Hybrid but it does have a product Number FLM10200 & 10300. Nothing on the FLM website about them, I did find an link from there old site mentioning the number, but of course the link is dead. Only other place I can find anything about these numbers are from Stormer Hobbies, https://www.ssl-stormerhobbies.com/c...ns&pn=FLM10200 It says Hybrid, but I'm not too sure, doesn't give any details.
Have sent a nice email to FLM, including the pics, so hopefully they get back to me.
Actually just found them at RC Bros aswell?
http://www.rcbros.com/cart/scripts/p...?idproduct=231
