12.15.2009, 11:50 PM
Link you should put a lathe bit in the drill press (leave it turned off). With a two axis vise and the motor running, all you need to do is hold a bit stationary and it would work great!
I would, but this vise is a cheapy harbor freight model and the press is not really good either. I would like to get a small lathe, just to get a feel for it.
12.16.2009, 12:34 AM
i spoke to mike he "might" setup a conversion service to turn rotors from 6 to 5 or sell modded motors - would you pay for mike to grind your shafts?
12.16.2009, 12:03 PM
I beg your pardon?!
Duster_360
12.16.2009, 12:56 PM
Sorry, I'd rather see Mike sell even a limited selection of pinions than offer that as a service. I don't want to cut the shaft on my 1717.
BTW, in case anybody from Castel is paying attention, the shaft size for teh 1717 is still shown on your chart wrong as 5mm.
Pdelcast
Pdelcast's Avatar
12.16.2009, 01:23 PM
We are changing the diameter for future motors to 5mm.
Patrick del Castillo
President, Principle Engineer
brushlessboy16
brushlessboy16's Avatar
12.16.2009, 01:24 PM
WOOHOO
by the way did anyone else notice the new 1512 1.5 1800kv motor. perfect for 6s buggies
Duster_360
12.16.2009, 01:33 PM
OK, thats cool for future owners, but pretty much kills any hope for 6mm pinions from RCM for current 1717 owners....
bruce750i
bruce750i's Avatar
12.16.2009, 01:42 PM
Maybe the 5mm shaft rotors will be offered seperatly?If one wanted both size shafts for one motor.
12.16.2009, 02:03 PM
I imagine there is only a small number of people who will ever actually own the 6mm version given what Patrick has just said, so everyone will write it off as a mistake pretty much & move on; Im sure Castle will take care of you if its that much of a problem getting 6mm pinions/ machining down the shaft to 5mm at home.
Unsullied_Spy
Unsullied_Spy's Avatar
12.16.2009, 03:11 PM
Glad to hear it Will the heli motors (with the shaved fins) have the 6mm shaft and the Monster Truck motors be 5mm? IMO that's the way it should have been from the start, but oh well.
The front bearing is 6x16x5, correct? Mine got some metal shavings in it from grinding the shaft down and needs to be replaced.
Pdelcast
Pdelcast's Avatar
12.16.2009, 04:39 PM
Yes, the heli motor will be 6mm, and the truck motor 5mm. It should have been that way from the beginning -- was an oversight on my part.
I'll have to get back to you on the bearing size - - working at home today (sick kids...)
Pdelcast
Pdelcast's Avatar
12.16.2009, 04:40 PM
Once we have the 5mm shaft in production, we'll offer a replacement rotor to those who got a 6mm and need a 5mm instead.
12.16.2009, 05:29 PM
Good stuff, but will you swap out for the ones that were "modded" to 5mm...? Nothing against my skill, but I would much rather have a properly turned shaft than my half-assed attempt!!!!!
Pdelcast
Pdelcast's Avatar
12.16.2009, 05:39 PM
Sure -- but it will be about 6 weeks before I have 'em here.
12.16.2009, 05:44 PM
No prob, I will most likely run this as is, see how it does. Thanks for taking care of us, means alot to me at least!
