01.08.2010, 12:56 AM
The 580 motor is a pile of junk- as tested by a couple RCM members who said they burnt up after only a couple runs, in a mild setup. Its a feigao afterall
I'd stick a nice fat 1717 in there and a 200amp hobbycity HV boat/plane esc, then use mech brakes = made of win.
Nothing against the 1717 but it is not enough motor. I have one in my lst. Good for a heavy/big MT but not enough for 1/5 scale.
I would say a 1527 would be the best bet, save for going to the 22 series neu. I doubt that 580 is any more capable than a 1521 plus it is less effecient. My 5th scale savage build will use a 1527 2y on 10s lipo. But that truck will be quite a bit lighter than a baja 5t. The chassis has to be heavy to deal with the bif gas motor, that bugger is heavy. I had planned to run a pair of 1521 motors in my 5b, but sold it as I just do not like 2wd.
Originally Posted by MetalMan View Post
I dunno how they managed to make it work in such a heavy vehicle, but I fried one of them 580L motors with higher voltage (lower kv) and only ~15lbs and center diff 4wd. A Neu 1521 took its place and fares much better.
A 1521 is a good motor. Moves my muggy around great! I have my doubts about the feigao motors, maybe good for 30k max rpms and water cooling. I do not think the magnet assys can handle higher rpms. I still like the kb45 motors better, and they are cheaper.
bustitup
01.08.2010, 11:03 AM
perfect motor for that truck would be the Scorpion 4035-800 outrunner on 10s
very very reasonable and more torque than most Neu motors at 1/3 the price
I emailed them with a Q and heres the response
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
I emailed them with a Q and heres the response - 01.07.2010, 09:48 PM
To: wangan9
Subject: You've received a question about your eBay item, Custom Electric Baja 5T 1/5 Truck RTR 2.4GHZ HPI Comp !
Sent Date: Jan-07-10 16:39:28 PST
Dear wangan9,
Hi,
Awesome build, but I'm concerned the Motor and ESC are not up to the task of pushing all that weight around efficently ? Have you tested this set up in a 25+lb RC ?
Thanks
J.M.
bondonutz
Dear bondonutz,
Hi, yes we built another one identical to this one for another customer and it worked great. The motor's low kv is enough to move this baja and top speed is over 50mph on the supplied battery. Thanks.
- wangan9 Did this answer your question? If not, let the seller know.
01.07.2010, 10:40 PM
maybe once for half a second. Oh well, we know better.
redshift
RC-Monster Square Tube
redshift's Avatar
01.08.2010, 12:45 AM
01.08.2010, 08:53 PM
Whats the CC motor bigger than the 1717 again? 2050 or something- that would be the ticket I guess
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
01.08.2010, 09:29 PM
this guy sounds like one of the noobs who dosent know he's a noob
