thzero
01.16.2010, 10:22 AM
I have just as much ground clearance with my RC8T as I do with my Savage (measured underneath the diffs), the RC8T (same with apply to any truggy) also has slightly wider stance with longer a-arms. Droop, well it is slightly more limited due to the droop adjustment mechanism; cut that off and well you have more droop available with the longer a-arms. The ground clearance you get for the raised TVPs between the front and rear of course completely goes away with a flat bottom chassis.
Not so. Show me a truggy that has the kind of ground clearence potential this will have as far as the natural droop of the arms.
BitHed
02.12.2010, 02:04 AM
Hey Ho :) Following this one...
My biggest issue in getting the bulks onto a flat plate was eliminating forward / back flex...and trying to tie in the front and rear bulks together...
Mine takes the old hellfire center diff which is still going well...will watch this thread and chime in when i think i can sound like i know what im talking about :)
ADDED: What are you going to do about the front kick-up? I actually sat the bulkheads on with their alloy skidplates still on and just bent up the front to match...unfortunately the front is lightly crooked :)
