01.16.2010, 10:10 PM
"sturdy" is relative
Well, do you think the cen stuff is stronger than the losi parts? The diff case looks similar in design, but the cen appears to be plastic. The diffs themselves look to be stronger, less teeth and larger module. I know the cvds are stronger than the savage stuff.
So you're going to do something like this?
I can't find the other pic of the centersection, but the axle tubes had another washer welded on and the tubes were bolted together with a t/e-maxx diff sandwhiched between. From what I remember it held up very well, he ended up bending all the suspension links, not the axle. I think doing something similar where the tubes unbolt in the center would be stronger, and easier to assemble/disassemble than having a continuous notch for the cvd's and diff to come out of. Just tossing it out there, can't wait to see some pics.
I plan to use regular knuckles, and weld "c hubs" to the axle tubes. The cvds would be assembled to the knuckles with the cen 23mm hexes and then the whole deal slid into the tube and attached to the c hub. This will require that the knuckles be removed to allow the diff to come out, but it will be 2 wheel nuts and 8 screws max to get the diff out.
I really want a 1 piece axle. My design should be stronger than any sort of split axle, despite having notches for the diff to slide in. Mainly looking to make 1 wheel landings repeatable...
Overdriven
Destroyer of Tires
Overdriven's Avatar
01.16.2010, 11:34 PM
Oh, duh. Don't know why I was thinking your axle tube would be notched the whole length for the cvd. I need some sleep, the days are blending together. Can't wait to see a finished axle though. I've been wanting to do something similar for a while too.
NickRummy
NickRummy's Avatar
01.16.2010, 11:52 PM
Subscribed! If those axles turn out nice I'll take a set
01.17.2010, 03:15 PM
I would love to see some straight axles that can take a poundding like the real thing! A scale version of the axles in a real MT would be cool, think of the abuse they take, 10,000lbs going 50-60MPH and falling from 40'+, thats some serious abuse. They still fail from time to time but that is alot of stress on them.
Can't wait to see teh end product Linc
The jugg axles are pretty close to scale versions of the MT axles, but I doubt they would take much of a beating. I am gathering parts right now, so I should be able to get some work done on these soon...
The notch will be a weaker area, but hopefull the gussets will add strength where needed...
Yeah, I hope they are somewhat successful... Not sure If I will make duplicates, or not, depends on how easy they are to make!
I would like to see some better pics of how you mounted the links on the x factor axles. I had an x factor a while back, but it was a turd, still have the stock chassis, and shitty tires!
JThiessen
JThiessen's Avatar
01.17.2010, 05:35 PM
Why not step up to the next level on your diffs. Seems like like we are almost at the limit of 1/8th scale diffs now. I'd think some of the 1/5th scale rigs would have something beefier for you to use.
01.17.2010, 06:06 PM
I had thought about that, not sure where to go or what to use... Plus I would like a diff setup that has a case, as my design kinda requires that.
JThiessen
JThiessen's Avatar
01.17.2010, 10:12 PM
I hear you on that. I looked around at the various 1/5th rigs, and saw nothing diff wise that blew me away. Most just have 2 spider gears. Cen's got a really funky, and quite complex assembly for theirs.
I did see that MCD has what they called "pneumatic" tires on their M/T's. They also have what they call a "lock-unlock" center diff system. They make it sound like it can be locked by the user.
I really like the hydraulic disc brake systems they have too....
