Brake Setting when using mechanical brakes?
teknorc
03.09.2010, 11:02 PM
Set to Forward/Brake only
Set brakes to Custom, then 0%
Set drag brake to 0%
The actual brake servo movement will be done with mixing on your transmitter or with the use of a Y harness.
Tekno RC - Performance Parts
teknorc
Find all posts by teknorc
2
Thomas Porfert
03.10.2010, 01:13 PM
+1 for TeknoRC. If you decide to use the Y-Harness on the throttle channel, just make sure your linkages are adjusted so the brake does not engage when applying throttle.
Thomas Porfert
Castle Tech Support
Thomas Porfert
Find all posts by Thomas Porfert
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
Off
