03.13.2010, 06:49 PM
Nifty, but can you add a bit more variance to the pinion and spur options. Like 30t min and 70t max for the spur and 10-30t for the pinion?
I am guessing by interval gears in the settings screen you mean internal gearing in a transmission, like a revo has for example?
Cool, I like it.
micke_b
03.13.2010, 07:06 PM
Cool, I like it.
Yes you can, just change the "center" on the interval for the spur or pinion. For example you could have a pinion range of [10-30] if you set the center to 20, and for the spur, a center of 60 gives you [50-70] The range of the slider of the pinion and spur will always be center value -/+ 10 if I use a wider range it can get hard to pinpoint the teeth count you like with your finger. ;-)
Oh, and yes, the internal ratio is transmission + diffs, that is everything after the spur gear to the wheels. In a revo you have gear box + diffs, in a 1:8 buggy you only have the diffs, like 4.3 in my Ve8.
03.13.2010, 10:31 PM
Makes sense now. Thanks for claifying that. I will have to figure out the ratios for the monster trucks. Maybe if you decide to make another version have another feild that could be left at 1 for buggies/truggies and then have other ratios entered in for vehicles with transmissions?
Otherwise nice app!
