03.27.2010, 10:47 AM
I am going to check everything out tonight.I will set the timing at 0 and go from there.I am going to try a 6s lipo my friend has and see if that helps.I have a deans connector on the esc that I will re-solder also.Hopefully one of these things works.I saw a video from 93Formula that has this truck doing a standing backflip on 4s though and he is using the same center diff I am from the cen matrix with a mamba esc.I do believe mine would also do a standing backflip now if I locked the center diff.I will try to change the gearing like others have said if the other stuff doesn't work but I think if I gear it for more torque than it has now I will start breaking things.Driveshafts etc.
