Originally Posted by nuz69
Try a timing at 0 first then us how its working !
I just tested the timing at all of the timing options.It cogged at every setting.It seems though as long as the truck is moving in either forward or reverse it doesn't cogg.If I am running at 1 mph in reverse and give it slight forward throttle,it just goes forward without cogging.I did notice that if I move the pinion gear even slightly to turn the motor,my motor fan that is plugged into the reciever changes rpm's.If I do 1 full rotation with the pinion,the fan speeds up and slows down 2 times each.Just something I noticed.
