nitrostarter
nitrostarter's Avatar
03.29.2010, 12:32 AM
I just ordered Losi part #losb3120. Its the new bevel geared that come with the E-LST kit. With this gear change in the transmission, it should open up gearing choices a bit. This will make the transmission overall gearing to be 1.72 and if you do the swap mod it will be 1.575. This will make gearing the lower KV motors much easier while being limited to Mike 26T pinion of the 2-speed adapters.
N. Rustler conversion
