Ask and you shall receive. The tray is built on the same concept as the MBX6 and 808 trays in that is is a direct bolt on and is designed to allow wire routing under it, as well as ESC mounting in the rear. The pictures show the whole car converted with all RC-monster parts - 2 speed adapter and gears, double servo plate, battery tray and kyosho motor mount. :)
