04.04.2010, 09:35 PM
The Thunder ac6 is what alot of guys over on beatyourtruck have been using- a few have reported issues, mainly cold solder joints between the built in powersupply & the charger cicuit itself ( same issue with the skycharger ).
If Hobbyking is out of the question, and you want a quicker charger than all the 50watt limited ones, then have a general google around and read reviews- a ~150watt charger and suitable power supply would give quick charge times; I like the iCharger line up, been reading great stuff about them ( top name brand like Hyperion ).
Erevocanuck
04.05.2010, 04:35 PM
I plan to buy a Icharger 208B soon.It has optional balancing board that you can connect multiple batteries.Down side for me is that my power supply is 13 volts 20 amps(260 watt) and the 208B is 350 watt charger.
