04.26.2010, 10:48 PM
I think it would be possible, but you'd need to run the motor at max throttle with any given voltage ( lower the better really ), then get an accurate rpm reading. Then its just a bit of simple maths to determine rpms per volt = kv rating. Thats assuming there isnt any voltage drop, but without any load on the motor ( bench test as such ) there shouldnt be really, or not much anyway.
Famous last words....
Duster_360
04.27.2010, 12:02 PM
Hacker's ad for the 5mm shaft still comes up and lets you put it in your cart - guess you'd have to call them to be sure its still available....
http://www.aero-model.com/C50-Maxx-Rotor-5mm-shaft.aspx
