simplechamp
simplechamp's Avatar
05.05.2010, 03:38 PM
The size usually refers to the piston bore, so measure that. The actual outside diameter of the shock body on the big bores will be larger than 16mm, probably closer to 19-20mm.
steveo
05.05.2010, 09:39 PM
yeah i just went for it and got the non big bore shocks and it was correct, the first post i had what happened was i got rc8b shock ends
