whitrzac
Can't catch this...
whitrzac's Avatar
07.02.2010, 01:18 AM
L can rotor from a feigao?
I can give it a try, but I need to order one...
does anyone(linc...) that they want to get rid of for cheap
steveo
07.02.2010, 05:19 PM
the rotor from an L size motor will work i have used before, i had the same issue with my shaft, but for only $10 price difference for the L motor to use its shaft the quality is not the same
whitrzac
Can't catch this...
whitrzac's Avatar
07.02.2010, 05:55 PM
I was planing on getting an ebay/HK motor feigaos are tooo much
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
07.02.2010, 06:53 PM
http://www.castlecreations.com/produ...pair_kits.html
1512 size? rotor Diameter may be a problem. But only $25
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
whitrzac
Can't catch this...
whitrzac's Avatar
07.02.2010, 07:14 PM
the rotor from a tekin buggy motor fits, but the 4pole VS 2...
aka it cogs like a ******
steveo
07.02.2010, 11:31 PM
but its the stator that is 4pole, does the rotor have to match, are they 2,4,6, pole rotors?
i dont know if there is an easy fix i would like to get a good quality rotor for my c-50 if this works
sikeston34m
sikeston34m's Avatar
07.03.2010, 12:17 AM
Yes, they have to match.
2 pole is N-S
4 pole is N-S-N-S
6 pole is N-S-N-S-N-S
This is the Magnetic Configuration of the Stator AND the Rotor.
Mismatching these doesn't work.
