Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
nuz69
nuz69's Avatar
08.12.2010, 05:24 AM
IMO it's not a Castle motor, look at the endbell fixations screws : lateral screw (very fragile system).
I would bet on a low cost chinese motor like feigo or hobbywing EZrun motor...
HPI marketing... Another big toy RTR, "Ready to Repair"
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Pdelcast
Pdelcast's Avatar
08.12.2010, 02:37 PM
The endbell screws are exactly the same as on the 1515 motor -- never seen one broken -- ever. Just we used them on both the front and back of the motor to lower costs (the front-endbell screws moutns on the 1515 are really expensive to machine -- lots of time on the CNCs)
Patrick del Castillo
President, Principle Engineer
nuz69
nuz69's Avatar
08.12.2010, 03:23 PM
It is the same screws of the REAR endbell I meant, the front endbell on the NEU-CC 1515/1y has stronger screws longitudinally mounted. I thought you change the system on the 1:10 scale motors for this reason, sorry.
I broke a motor front endbell with this system (ORION 2300Kv 4 poles), but the motor was hold by the front endbell, if in the HPI chassis the motor is mounted with front and rear fixation they should be no problem...
Pdelcast
Pdelcast's Avatar
08.12.2010, 03:40 PM
Also, the front end-bell is glued in place, so there shouldn't be any issues.
Freezebyte
08.12.2010, 03:46 PM
Awesome, thanks Patrick!
nuz69
nuz69's Avatar
08.12.2010, 06:09 PM
I am very happy with Castle Stuff, but I had a bad experience with one of this lateral screw on my 1520/1Y :
Semi Pro
Semi Pro's Avatar
08.13.2010, 02:00 PM
i have never broken one myself, they always strip before you can do that
Pdelcast
Pdelcast's Avatar
08.13.2010, 03:16 PM
Be aware -- those are TORX screws, not hex screws -- if you use a hex driver, you might strip them...
