Drag brakes in 1/8 Ep slower? -
08.16.2010, 07:26 AM
I am changing to a new racing style, with drag brakes. Prevously I race n brake but sometimes I brake too hard n the car spin out or overturn even with 20% brake setting.
I realize drag brakes I let go the throttle earlier n turn in tighter but I am slower in timing. If I throttle too hard after a stop I spin out too.
Nowadays my track is muddy n wet not good with traction.
Any advise?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
08.17.2010, 04:48 AM
no one knows?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
08.17.2010, 05:57 AM
get rid of drag brake and learn proper throttle control.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
08.17.2010, 09:20 AM
Really you think so? No one uses drag brakes in 1/8 Ep?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
08.17.2010, 09:37 AM
drag brake makes jumping very hard and sometimes you need just roll the car without any throttle
Radek
*EX-10 Eurus*
08.17.2010, 09:56 AM
I jump better with drag brakes n during cornering it's tighter n ESP great when there's a turn after a slope I can turn out tight.
But I am not sure is it I am not aggressive enough or I let go the throttle too early for the drag brakes to kick in.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
08.17.2010, 10:19 AM
I drive my electric truggy like nitro car. Hit throttle hard and brake as late as possible.
So far worked great. Podium at every race and first place if I had enough time to setup car for the track :).
Radek
*EX-10 Eurus*
08.17.2010, 10:38 AM
i used to drive this way but i brake too hard it flip often. now with drag brakes my timing is 2 sec faster.
i am always podium but i needed more consistent braking.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
That's All Folks!
08.17.2010, 03:08 PM
Works for some, I prefer no drag brake as well as drive like a nitro.
08.29.2010, 07:27 AM
I don't use drag brakes. It tune my EPA of the brakes on my transmitter until I'm pleasured with the braking strength. It's usually not very hard since the car the would spin out then. It's all about throttle control mate. Like wallot says, sometimes you just need to roll through a corner and I don't know how you do that with drag brake.
If you want more steer tweak your setup and use your finger to brake.
Brake before the corner, enter the corner, hit the throttle in the corner/at exit.
08.29.2010, 08:47 AM
I guess so, I am changing back to no drag brakes n throttle control better. Now I am testing 4s setup vs 6s
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
is lovin life brushless
10.08.2010, 05:28 AM
i found with drag brake when the my trug was in the air it wood dip down nose first like i had hit brakes while airborne. better to go without and get used to free rolling in and around corners then hittin the loud button out of the corners. Brake Late And Turn,B.L.A.T racing
associated rc8t..........e
tamiya f104pro,r,w.f103gt.tb02,ta02
nuova faor sf501
avatar is pic of what our cat does with empty boxes left over from rc purchases
10.08.2010, 02:35 PM
i run drag brakes on everything for racing, its a much better form of in air control, shifts in angle can be made much softer by useing it, if you are spinning out alot then you have to heavy of center diff and rear diff fluid, it can also come down to changeing tires and going to a softer tire foam.
other thing you can do is -
add more rear toe-in
brake alittle later so you dont power out of the corner so much
Originally Posted by Semi Pro
Originally Posted by BrianG
10.15.2010, 09:51 AM
i stopped my drag brake now race without it. much faster
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
