armourbl
08.24.2010, 10:49 AM
Originally Posted by BashemSmashem View Post
Looks like the rotor is becoming detached from the shaft , I have one that has done the same thing !
Castle should replace it for free cause it looks like the newer endbell and I dont think those motors have been out for a year yet .
I sent them a picture of it too. Still waiting to hear back from the tech. Fingers crossed. I haven't sent it in yet, trying to find out before I do send it what I can expect.
ben
Pdelcast
Pdelcast's Avatar
08.24.2010, 10:52 AM
That's actually an older motor --
The newer rotors have the rotor mechanically locked on the shaft with a pin -- and that type of failure shouldn't ever happen with newer motors.
Usually, this type of failure occurs when the motor is too hot -- the epoxy holding the rotor on the shaft softens at about 180C
But it can happen if the rotor is incorrectly built as well.
Contact tech support, and we'll send you a new rotor for the motor.
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
armourbl
08.24.2010, 10:54 AM
Thanx!
Patrick
Thanks Patrick. It is great that you frequent the forums.
What about the endbell? Does it actually have a hole in it or did the shaft chew through it? If so, what do I do about the hole?
ben
armourbl
08.24.2010, 10:58 AM
Should have mentioned that the motor comes off the track after a 20 minute main at 170 degrees at the hottest location, cooler on other parts.
I run 4S batteries and have to do a battery swap to make the 20 minutes. Seems like once the motor gets to its peak temp, it stays there. I get the same final temp during qualifiers too.
ben
Pdelcast
Pdelcast's Avatar
08.24.2010, 11:12 AM
ben
The end bell is fine -- that's just a sticker over the bearing. :)
armourbl
08.24.2010, 11:18 AM
Awesome. I'll just put some clear box tape over it to keep dirt out.
I emailed the tech I've been corresponding with to ask for a replacement rotor.
Thanks again Patrick.
ben
sikeston34m
sikeston34m's Avatar
08.24.2010, 05:39 PM
Yet, another testament to Castle's GREAT service and support!
Way to go Castle!
armourbl
08.24.2010, 05:41 PM
Way to go Castle!
Absolutely. Got the email from the tech after lunch today that the new rotor is in the mail, even got the tracking number.
ben
