Freezebyte
08.26.2010, 08:40 PM
Once you get a temp gun, (should have ben bought long ago) I think you'll see your probably worrying for nothing.
Raising the punch control will help with temps as well, make sure your motor timing is set at Low or Normal at the most.
Punch is at 10% right now, timing is set to default
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.26.2010, 08:43 PM
I know, read it in the first post.
Like I said, if you raise the PC it will help w/temps
I think motor timing at default is "normal" and thats OK, but again on low it will help w/temps also.
