09.07.2010, 09:47 PM
Lots more info would be helpful.
What's the vehicle, does it have a tranny or CD, what motor.
But yes check the motor, the shaft will have a tick back and forth but should not have a 'clunk', and check for resistance spinning the motor shaft while pushing and pulling on it. Where is linc to take that out of context....
And check side to side play on the shaft, again should be VERY little shuck, or none.
What do trannys and Cross Dressers have to do with R/C? How much should one resist spinning their shaft? Such incoherent babble......
A RC Dude
A RC Dude's Avatar
09.07.2010, 11:24 PM
thanks guy!
redshift-i rolled my car without the pinion gear on the motor down my drive at 20-25mph with no sound. but when the pinion is on, the noise appears but is a LOT more noticable wile holding the same speed or coasting, i can't even hear it when i'm on the gas or brake much.
did you check to see if somebody put a car supercharger on your e-maxx? This all sounds very suspect.........
the only supercharger i see is the big blue brick of a battery
redshift
RC-Monster Square Tube
redshift's Avatar
09.07.2010, 11:43 PM
Mr. Dude has to learn some of the finer points. Sometimes you have to get intimate with the inner workings, poke around a bit. Occasionally some sweet soft words can coax the problems out and if you're fortunate, it'll respect you somewhat the day after.
JUST TAKE IT APART!
You could be working on it now, now, and now.
A RC Dude
A RC Dude's Avatar
09.08.2010, 07:31 PM
JUST TAKE IT APART!
no i can't...been too busy with school and all
