coolhandcountry
coolhandcountry's Avatar
02.27.2006, 09:17 AM
The limit is batteries. You can have an awesome motor with cheap batteries and it still suck. 60 mph is not real bad to reach. Don't get me wrong it does take some power and money. At minimum I would run a xl. A 1950 would do better. I think the 22 series may be what you looking for. Consider a 2240 10t.
Peace!
Country
Help support the
Rc-Monster
Buy here
nl12
nl12's Avatar
02.27.2006, 09:53 AM
I am going to use lipos, 6 cell was the original plan I may go to 8 cell lipo if needed (space permiting). 2240 10t has 1480kv 22.2 volts would only take the motor to 32856 rpm probably 30000 rpm realistically, would 8 or 9t be better for 22.2 volts? Would a 1700kv 22 series on 22.2v pull too many amps do I need to go 10 turn and higher voltage if I want a 22 series motor?
