09.29.2010, 10:32 PM
Originally Posted by bigbadtaz View Post
locking the spur use can use drag break instead of another servo........also keep in mind that this was a 2 speed and we are using the 2 gear which in on a one way bearing. which will not engage unless the 1st gear get up to speed ..hope this help
On my mugen I already removed first gear. I will try the drag brake set up as well.
I know all to well about punch control as well. My mbx5T is set at 70% to help reduce wheel spin and prolong my battery with my 1520 5S set up.
Have you tried your set up w/a 4s set up? I like the 4 or 5S set up w/a 2650 castle or Tekin motor. I would prefer to use 4s to help keep weight down but, 5s is just more fun!
thanks again for all of your help and thoughts
bigbadtaz
bigbadtaz's Avatar
09.30.2010, 12:52 AM
well we are trying to go as fast as we can so were using 6s setup for now when we get more guy with 8th scale setup we will go for more of a race format .....
