09.29.2010, 10:32 PM
Originally Posted by bigbadtaz View Post
locking the spur use can use drag break instead of another servo........also keep in mind that this was a 2 speed and we are using the 2 gear which in on a one way bearing. which will not engage unless the 1st gear get up to speed ..hope this help
On my mugen I already removed first gear. I will try the drag brake set up as well.
I know all to well about punch control as well. My mbx5T is set at 70% to help reduce wheel spin and prolong my battery with my 1520 5S set up.
Have you tried your set up w/a 4s set up? I like the 4 or 5S set up w/a 2650 castle or Tekin motor. I would prefer to use 4s to help keep weight down but, 5s is just more fun!
thanks again for all of your help and thoughts
