Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.05.2010, 10:50 PM
Yeah, I forgot to mention that I plan on checking my settings befor I change gearing (I think PC is set at 80% ?)
After second run the motor was 137*, only let it rest after first run long enough to change packs.
The ESC was barely 90*
sikeston34m
sikeston34m's Avatar
10.05.2010, 11:07 PM
The motor can handle much higher gearing than that.
If you were to do an Eagle tree graph on this setup, I imagine it's spiking really HUGE on take off. I would definately play around with the ESC setting to tame those spikes as best I could. Without taking away performance, of course.
I remember a setup in my E Revo. A 36-60mm Medusa Can that was 1500kv.
Gearing was 22/40 using Mod 1 gears.
The motor handled this just fine with a heat sink/fan setup.
BUT.............on 4S it would literally carry the front end around.
I also remember running 2-4S 4000mah 20C packs in parallel with this setup, for some really good runtimes. Well..........one day I charged em up and hooked up a "SERIES" connector by mistake. This shoved 8S power through the ESC.
It armed, so I took off running. Not realizing what I had done. Until I seen the truck do a 30mph backflip when I stabbed the throttle.
I immediately realized my mistake and changed back to paralled. Everything survived.
We do need a 8S Castle Controller.
