armourbl
10.10.2010, 04:43 PM
Yeah, you got the air version. The air version has a 6mm shaft, vented endbells, 1500kv, and motor wires are extensions of the coils (and are stiff). The car version is 1580kv and looks much more like your 2200 motor, but bigger.
There were inventory/boxing issues with the air and car version at Castle. Contact them and chances are they'll do a swap with no problems...
I know this wasn't an inventory issue. It was my fault for not noticing the details of the item I ordered.
Have you been happy with the air version? Any issue with the holes in the endbells and dirt?
Worst case scenario I can just use a plastic spur and a alloy pinion drilled out to 6mm.
Forgot to mention that I emailed Christy at CC. I'm going to wait until I hear back from her before I do anything with the motor. Right now I'm leaning toward exchanging it for the 1520/1Y 1600kv motor if that is an option she makes available to me.
ben
Bmr4life
10.11.2010, 09:40 AM
ben
Are you sure you ordered the wrong motor. CC sent out several Air 1717 motors to people that ordered Car versions.
armourbl
10.11.2010, 10:09 AM
Yeah, it was my mistake. It says Air on the invoice.
I got an email back from CC this morning. They said I could exchange it. Since I have this opportunity to make it right, I need some advice from everyone.
Should I go with the 1717 1580kv car version or the 1520 1600kv instead. The later is a bit smaller diameter and will likely fit with more clearance. Seems like 20kv difference really wouldn't be noticable.
The air version has flats milled into the can that provided some extra clearance from the chassis. I'm not sure that without the milled flats that the 1717 will fit.
Please advise.
ben
Bmr4life
10.11.2010, 11:05 AM
Please advise.
ben
Pretty sure CC is out of the 1520, but you can ask.
Also, they got my invoice wrong, says AIR, even though the email confirmation of what I ordered says CAR for my 1717. Luckily I contacted them in time to get it corrected before it shipped out. Its supposed to arrive this week so we'll see if it really got fixed.
As for which motor. The 1717 will have more torque. The 20kv difference is negligible like you said. I think I read that the 1717 is amp hungry, but I'd think all of these larger motor are similar.
armourbl
10.11.2010, 11:32 AM
Looking on their website, it does appear they are out of the 1520 motors. They are no longer listed on the clearance page.
Looks like I'm sticking with the 1717.
ben
10.11.2010, 10:12 AM
...Have you been happy with the air version? Any issue with the holes in the endbells and dirt?...
I did not use the air version. But really, aside from the larger 6mm shaft, there is no difference between the "air version" of a CC motor and a "classic" Neu motor. Lots of us used/use Neu motors in our vehicles with no issues. Most people cover the vent holes, and maybe find a way to help support the stiff wires from excessive flex (jump landings and such). Just a matter of convenience really.
