ChrisAttebery
10.29.2010, 06:36 PM
I have this system on the way. Since this motor has so much torque I'm wondering if it is going to present a problem for those of us running 2wd.
Does this ESC have a torque control setting?
If not, can torque control be added to to the firmware?
If torque control was available, could you set it up so that when Torque Control is enabled via Castle Link Software:
A) "Punch Control" is disabled
AND
B) Field Link could use the Punch Control adjustment to adjust the Torque Control?
Thanks,
Chris
